Digital optical cable dilema
Discussion in 'Cables & Switches' started by iandmcneill, May 11, 2005.
  1. iandmcneill
    iandmcneill
    Dec 11, 2002
    58
    I have a sony amp that has coax and optical digital connections. My xbox is connected to the optical and the coax used to be dvd player but that function is now carried out by the xbox. Sky is connected to the amp using left/right connection. However :) I am dumping sky and have gone with a freeview box (sony du800x) that has optical sound out only. Is there anyway I can get a scart cable that will take the sound signal and "put" it onto cable that can go into the amp's l/r tv connection so I can still get sound out of the amp for tv. Or perhaps even better, some way of sharing the optical connection.
    Thanks in advance and apologies for lame technical descriptions. AV is not my stong point :)
    Ian
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    What you need is a scart to 3-phono cable (1 video output and 2 audio).
  3. jon_mendel
    jon_mendel
    Jan 15, 2005
    852
    +9
