digital on to dvd disk
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dee416, Jan 24, 2003.
  1. dee416
    dee416
    so far i have little experience on this i'm using pinnacle 7 and can only get about twenty odd minutes of footage on one dvd disk what am i doing wrong. can i adjust the resolution/ quality to allow more footage per disk.
  2. dee416
    dee416
    noticed a black dot on envelope at left of post what does this mean.
  3. EvilMudge
    EvilMudge
    Sorry, can't remember what the black dot means, someone did tell me once, don't worry about it though.
    Thought I'd ask the obvious question, how much disk space do you have free on your HD?
    Pinnacle has to write a temp file before writing to DVD, and if there's not enough space free on your HD then it can't write a full DVD.
  4. OGIII
    OGIII
    Means it's a thread that you've posted in
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    How is your cam connected to the PC? Analogue or DV (digital)?
    On a PC the maximum length of footage that can be captured in analogue is approx 18 minutes( or 8 min in DV). This is due to the maximum file size of 2Gb. Some programmes can capture larger files, but this is done by the capture software splitting the capture but linking them together within the programme. IIRC this can only be done with digital capture.
    The easy way around this is to capture multiple 18 min. sections of footage with a slight overlap and then edit together in Pinnacle 7.
    Mark.
  6. dee416
    dee416
    even when editing several clips the time bar on the screen is at maximum with about 26 minutes of clips, can i adjust resolution or quality to allow more footage.
  7. dee416
    dee416
    17.5 is max at a time however am only geting say30mins on to a dvd disk that is the problemas i am able to do multiple17.5 clips to the 40gb hard driveavailable but only 4.7gb on a dvd disk, have quality at digital max should i change this to say mpeg or something.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    DVD-R has a capacity of 4.7Gb
    The format for DVD files is MPEG2
    Uncompressed DV footage is 4 minutes per Gb
    DV file to a 4.7Gb DVD-R = just under 18 minutes
    It sounds to me that you are copying uncompressed DV files to a DVD.
    Compress the file into MPEG2 before writing to disk. This will give you full DVD quality (subject to origional quality of footage) and a lot longer final film on each disk.
    Mark.
  9. dee416
    dee416
    Thanks Mark sounds like thats what i needed to know, havent had a chance to try it yet but confident that it will work.
  10. dee416
    dee416
    still got the same problem all u r numbers r spot on mark however dont seem to be getting the mpeg2 compression thing to work still getting about 20 mins for 4.7gb please help.
  11. dee416
    dee416
    got it at last the mpeg2 thingy only happens when creating the movie after edditing not when capturing as i was expecting , anyways thanks again.
  12. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    It may be worth looking at aftermarket MPEG2 encoders
    The one in ULead DVD Movie Factory is bad
    TMPGEnc is quite good!:smashin:
