Digital keystone
Discussion in 'Projectors, Screens & Video Processors' started by spanx, Jun 12, 2003.
  1. spanx
    spanx
    Hi all,
    I've been doing a bit of research concerning a new PJ, and have kind of settled on either the Sharp XV-90 or the Pan AE300.
    However, one thing eludes me. I know these projectors all keystone the image to remove the trapezoid effect for ceiling mounts, etc. I have to problem where my screen is facing a door, so the projector will have to be situated to the right of the door (i.e. not directly facing the screen). Do these projectors handle this situation, or will I have to rethink the room?
    Many thanks...
  2. Kramer
    Kramer
    Will let others comment on the PJs you mention, but the HS10 has both vertical & horizontal correction (digital).
    IIRC, the Z1 has both forms of correction (optical). Digital correction does effect PQ - optical lens shift would be a better option IMO.
    Why not block up the door & thus avoid any correction?
    I would :D
  3. HappyLad
    HappyLad
    AE300 also has horizontal & vertical keystone correction.
    Got to agree with Kramer though, Keystone correction has a detrimental effect on PQ. Especially when viewing text, like on a PC desktop.
    If you've no choice with the room layout then I guess it would have to be one of the compromises that you have to live with.
    Good Luck
  4. spanx
    spanx
    Hmmm,
    I thought there would be downsides to keystoning
    Ho hum - my only other option is bringing the projector to about 9' from the screen, but I figured this would be too close.
  5. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +87
    Hi Spanx,
    My DIYprojector is 8' away from the screen, and put's out a screen size of 85" diag.
    And the quality is great via the htpc....
    Cosmic023
  6. spanx
    spanx
    Of course, as my wife cunningly pointed out, there is actually a projector sized space ABOVE the door. Damn her and her common-sense.
  7. Vorlon
    Vorlon
    Hi spanx
    you can always rely upon the other half to solve problems in 5 minutes that you've been pondering for days !!
