Digital inputs on 3801
Discussion in 'AV Receivers & Amplifiers' started by mm2, May 3, 2001.
  1. mm2
    mm2
    I plugged the the coax into the amp but it only works when i switch it to cd input. It then displays digital cd. How can i get DTs to work from my dvd player or do i need to buy a fibre optical cable
    Minn
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    It sounds as if you need to access the digital inputs page of the OSD setup. You need to set the DVD input to Coax. You will also need to assign another input to the CD, maybe optical 1, and for this you will need an optical TOSlink cable.
    Rick
