Digital in to Solo Music
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Cassandra, May 7, 2007.
Tags:
  1. Cassandra
    Cassandra
    Mar 25, 2006
    Is there a good way to get digital sound into the Solo Music? Some sort of box that can be bought that converts a TosLink carried signal to a line level output that the Solo can understand?
    Thanks.
  2. CharlieUSA
    CharlieUSA
    Nov 2, 2006
    95
    Vail, CO
    +8
    You're looking for a DAC, or digital to analog converter. What would be your budget for one?
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    Most, but not all external DACs tend to be fairly expensive. One which we use in store a lot is the Musical Fidelity X-DACv8 which retails for £1000.
  4. Cassandra
    Cassandra
    Mar 25, 2006
    I'm probably in trouble then. I already have an old SB Extigy box, which sort of does the job but doesn't seem to have an actual line-out. Running sound via the headphone out socket seems less than ideal. Interesting design decision there, I feel. Anyway, a hundred is probably the absolute highest I'm prepared to go, and even that would be pushing it. Am I out of luck?
    Given the Solo comes with digital out, I've never really understood why it doesn't have a digital in as well.
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    The digital ouput on the Solo would allow you to connect it to a good quality DAC such as the MF one I mentioned earlier and improve the performance significantly.
