Digital freeview tuners --> VGA
Discussion in 'Plasma TVs Forum' started by jwillans, Mar 18, 2005.
  1. jwillans
    jwillans
    Has anyone tried using a standlone freeview tuner such this one as direct input to a plasma via VGA? What are the result like?
    James
  2. jwillans
    jwillans
    I guess not! I've ordered one - I'll let you know the result.
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    where do they hide the price?...looks good
  4. jwillans
    jwillans
    Sorry mep, I posted that link because it had the best technical description. I bought mine from here the total cost was just under £110 including delivery.
  5. windfall
    windfall
    Oct 19, 2003
    2,432
    48
    LFC Kop End
    +68
    So - What is the picture Q like?
    I am thinking of something like this. Can you advise me on the following..
    My antenna feed comes via Sky+ Box to distribution amp in loft to wall panel. If I fed this into a similar device would the device do any signal increase do you think?
    What I am concerned about is the quality of the signal - it may look bad on a screen of this size, so would the DTV box increase the sky+ pictures whilst giving me a load of channels which should be crystal clear (freeview channels I mean).
    Hope you understand my issue and Q?!
    Tone
  6. jwillans
    jwillans
    Don't know about picture Q - it has not arrived yet (neither has the plasma for that matter).
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    cheers mate
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    looks like a PRoV or ProV+ with a DVB tuner................. it doesnt say if it has an analogue tuner as well so may not be ideal for tuning into a distributed Sky box....
  9. bowler
    bowler
    Jun 8, 2003
    223
    jwillans
    Have you got your Aver STB3 yet?
    If so how does it perform?
    Thanks.
  10. jwillans
    jwillans
    Yes I have got it and I have been testing it since the weekend. Although the picture quality varies from channel to channel it is generally good. The biggest problem I'm having is lip sync with my Panasonic PW6. I'm not sure how best to cure this, but I am certain that I am going to have to because it is at an unacceptable level. My DVD (Toshiba sd220) doesn't seem to have this problem. I have cntacted Aver, any other suggestions?
    James
  11. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    its the usual answer mate, common issue with FV / Sky and less so with DVD and really the answer is an amp with audio delay or a specialist audio delay box....I think it's Feltron that do one for around the £100 - £120 mark.
  12. bowler
    bowler
    Jun 8, 2003
    223
    Is it possible to try another freeview box with your set up?
    Also have you tried both audio outs from the Aver?
  13. jwillans
    jwillans
    Yes I have tried both audio outs. I have also tried listening to the sound using headphones to make sure that the problem wasn't an amplifier one. In both cases the lip sync problem persists. I only have VGA inputs on my screen so cannot try another freeview box.
    James
  14. jwillans
    jwillans
    Mep - Thanks. I can't find the company Feltron, is that the correct name? Also which amplifiers supports audio delay, I know about the Yamaha AX750 and RXV650.
    Thanks.
    James
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    felstron boxes are £165 IIRC thats for one device audio delay!!!!!!!!!!! a new amp or an Iscan HD is a better option....
  16. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    deffo....thought they were cheaper than that!
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  18. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    :D a tad on the overkill side I think!
  19. jwillans
    jwillans
    I could get the Yamaha RXV450 which has an audio delay facility. Does anyone know whether I can adjust this for specific channels? I'd like to set it for tuner input but not for DVD input.
    James
  20. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    nope it's a general override but I leave mine on -60. It's enough to solve any probs but not enough to create any...I never feel the need to change it.
