Digital Drive Version 2.0 Generally Available
Discussion in 'Subwoofers' started by Bruce Hall, May 16, 2005.
  1. Bruce Hall
    Bruce Hall
    We are pleased to announce general availability of Digital Drive software version 2.0. This software is compatible with all current Digital Drive subwoofers, and the upgrade is free of charge. The new version can be downloaded at:
    http://www.velodyne.com/support/digital_drive
    This new version features two different forms of auto-EQ, individualized EQ settings per preset, better navigation, default preset select, defeatable low-pass crossover and a host of other features. You can read about the new features by viewing the data sheet at the above link.
    You’ll need a windows PC with an RS232 serial port and a male-to-female RS232 9-pin “mouse extension” serial cable to perform the upgrade, available at any computer store or you can obtain one from Velodyne by emailing techhelp@velodyne.com. If you only have USB ports on your PC, you can obtain a USB to RS232 serial adapter at most computer stores.
    Note that version 2.0 restores defaults if upgrading from an older version, so note your settings before upgrading.
    I hope you find the new version useful.
    Thanks and Regards,
    Bruce
  2. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
    :clap: :clap: Great News Bruce looks like I'm off to buy a RS-232 cable :)
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,287
    Southsea, UK
    +96
    Hurray.:thumbsup:
    Just need to get the wife and kids out the house so I can play!:D
  4. samhain
    samhain
    Apr 1, 2004
    2,705
    South West Scotland
    +122
    Superb News indeed
