Digital coaxial
Discussion in 'Blu-ray & DVD Players & Recorders' started by jamesy999, Feb 9, 2009.
  1. jamesy999
    jamesy999
    Jan 9, 2009
    271
    Middlesbrough
    +15
    If a DVD player has a digital coaxial output does it automatically mean that it outputs 5.1?
    Cheers, James.
  2. IAN P
    IAN P
    Dec 11, 2002
    8,285
    +1,042
    Yes,what makes you suggest it won't?
  3. jamesy999
    jamesy999
    Jan 9, 2009
    271
    Middlesbrough
    +15
    It just doesn't mention anything about 5.1 in the manual for my DVD player but it has a digital coaxial ouput.
  4. IAN P
    IAN P
    Dec 11, 2002
    8,285
    +1,042
    What make is the dvd player?
  5. pauls898
    pauls898
    Jun 14, 2006
    193
    +7
    The Digital output will output what you ask it to. For example if you set it to just be PCM (Pulse Coded Modulation then all your get will be Stereo L&R. Or setting it to Dolby Digital / DTS then your get 5.1, or even 7.1 surround depending on the DVD your playing at the time that's if your AV reciever can decode that. Hope this helps, but there's no such thing as "Digital Coax" Coax is just coax lol.
  6. jamesy999
    jamesy999
    Jan 9, 2009
    271
    Middlesbrough
    +15
    Cheers paul but if it definately says coaxial digital out on the back off the DVD player.
