Digital Coaxial Vs Optical?
Discussion in 'AV Receivers & Amplifiers' started by Caimbeul, Jul 22, 2005.
  1. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +26
    Hi Just a quick question if you wouldnt mind... :lease:
    Is there a difference (apart from the way the work) betwen the two for connecting for audio.
    Thanks for any advice.
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    This one gets asked very often,and if you do a search,you'll find TONS of replies!
    In essence,for most sytems most of the time,you won't notice any difference in terms of sound quality,but if you're considering a high-end system,then a properly terminated coaxial interconnect can give superior results.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Agreed, but in other circumstances where the cables are prone to high levels of EMF (say a nearby phonemast or pylon) then optical may be a better solution as it's largely immune to these effects. :)
  4. Robosapien
    Robosapien
    alexs2 - What do you mean by properly terminated?
  5. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Only referring to the correct impedance(75ohms) being applied....any good quality digital cable should be able to match this.
  6. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +26
    Thank you kindly peeps :thumbsup:
  7. Bolf
    Bolf
    Jul 22, 2005
    398
    The Deepings
    +37
    Or over long distances optical has the edge over co-axial.
    so a short coax is the best
