Digital coaxial to small?
Discussion in 'Blu-ray & DVD Players & Recorders' started by kev3, Dec 24, 2003.
  1. kev3
    kev3
    Mar 3, 2003
    73
    'Ixos XHD408 (105) Digital Connect RCA to RCA,
    Connects your DVD, CD or DAC to your AV Amplifier'
    I just bought the above cable to connect my pioneer 565 to my amp for 5.1 sound. But the connector is to small?!
    Have i got the wrong cable? or do i need to force it in?
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    A normal digital cable for use between DVD and Amp will have a normal size phono plug on each end. Sounds like you bought another type of digital cable.
  3. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
  4. kev3
    kev3
    Mar 3, 2003
    73
    yeah, thats the one!
    that should fit shouldn't it?
  5. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Yes mate, I think the socket on the Dvd player should be orange and the socket on the amp marked 'Digital In'. Both should be normal size phono sockets.
  6. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I think maybe your trying to plug it into the optical out (or optical in on the amp). You need to plug it into the correct socket usually marked something like "COAXIAL DIGITAL". If it doesn't have coaxial digital on both your dvd and amp you may need an optical cable (assuming your dvd and amp have optical)
  7. kev3
    kev3
    Mar 3, 2003
    73
    cheers mylo, thought i was going mad!
    i'll give it another try tonight..
  8. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Have unscrewed the outer part of the connector slightly?
    I have a Ixos cable and you need to undo it, push it on to the socket then screw it back up, thus making it a tight fit.
  9. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,988
    Also be aware that, in an attempt to squeeze the maximum quality by making the best electrical connection, the plugs on some some high-end cables are intentionally very tight.
  10. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Kev, did u sort this?
