Digital Coaxial lengths V Optical
Discussion in 'Cables & Switches' started by mattross, Jun 21, 2005.
  1. mattross
    mattross
    Oct 23, 2004
    265
    +7
    At what kind of length will coaxial start to degrade compared to optical? I was thinking of a 5-6M cable and am not sure whether to go optical or coaxial. My AV amp has a shortage of optical inputs [I'm already using them all] so would coaxial be OK at this length? Is it more prone to interference if the cable is laid close to other cables and electronic equipment?
  2. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    5-6 M will be fine. As far as interference, you should worry more about the quality and integrity of your D-A/A-Ds in the system.
    regards,
    Gareth.
