Digital Coaxial Cables
Discussion in 'Cables & Switches' started by Steve-O 2007, Dec 30, 2006.
  1. Steve-O 2007
    Steve-O 2007
    Dec 19, 2006
    198
    +8
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
  3. Steve-O 2007
    Steve-O 2007
    Dec 19, 2006
    198
    +8
  4. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    All the signals are sent together, down one cable.
    Obviously, the units at each end have to have coax digital sockets, and be capable of handling 5.1.
  5. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,274
    Welwyn, Herts
    +942
    You do need a good quality cable for digital audio - video quality, not audio quality. RG59 cable doesn't define performance (just centre core diameter, really), but it's probably a good place to start. Shold be OK.
  6. Matt_C
    Matt_C
    Aug 14, 2005
    9,842
    Essex
    +1,832
  7. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    High quality coax cable is designed to handle signals at much higher frequencies without too much loss. They're often rated for resistance (75 Ohms or 110 Ohms) which helps the transfer from device to device without introducing signal reflections.
    Freebie cables don't do this. They're OK for analog signals like you'd get from the L&R audio outputs on a CD player, but they're not going to do much for higher bandwidth digital signals like the coax output of a DVD player.
  8. edent
    edent
    Mar 30, 2005
    345
    Oxford
    +18
    Nothing. If the 1 and 0 are getting through you'll hear 6.1 DTS-ES (or whatever you're passing through).
    The only slight risk is if the cable isn't that well shielded and picks up interference from the mains. Although I've got an old phono cable cable running next to mains, component video, speaker wire, telephone cable and ethernet and it passes the sound just fine.
    T
  9. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,274
    Welwyn, Herts
    +942
    I believe that could mislead people who come for good advice and information. Digital audio is a high bandwidth signal and analogue is not. The requirements for SPDIF are much the same as for video, and rather different to audio. For example, the characteristic impedance for SPDIF and video cables should be as close as possible to 75 ohms - source and sink impedances should be well-matched to ensure good coupling and minimal reflection and standing waves. Whereas for analogue audio it hardly matters - output impedance is generally low, and input impedance is generally high. Core, dielectric and screen requirements are also different. While a good video cable can be used quite well for both digital and analogue audio, you cannot say the same for analogue cable. It would work, but not well.
    Nick
  10. edent
    edent
    Mar 30, 2005
    345
    Oxford
    +18
    The max bitrate that a DVD will output for audio is 1.5Mbps - that's full DTS. Most AC3 bitrates are 443Kbps.
    You can take a few metres of bell wire and get the same digital[/] signal passed as an expesive "Digital Ready" cable.
    Try it for yourself, get a bog standard phono cable, some speaker wire and an uncurled metal coat hanger...
