digital coaxial cable = component video??
Discussion in 'Projectors, Screens & Video Processors' started by zcaps57, Jan 7, 2002.
  1. zcaps57
    zcaps57
    Hello. :)
    These days, I'm getting headache installing my 11HT projector. :rolleyes:
    I have 3 questions.
    1. Is it all right to use 3 coaxial(75 Ohms) cables designed for digital sound as component video cable??
    OR should I order custom made 10~15M component video cable?
    If I should order a dedicated component video cable, could you recommend me a good place to order please?
    I'm intending to use QED 10M coax cables to connect my SONY 9000ES DVDP to 11HT projector.
    2. I think UNCOL ceiling mount kit is cheaper than SONY branded ceiling mount kit. But you know the distance between the ceiling and the projector(how low the projector has to be mounted from the ceiling.) is it adjustable on UNICOL one?
    3. Could you also recommend me the best place to order the UNCOL and SONY ceiling mount kit?
    My questions may sound really basic and stupid. But please forgive me. :)
    Any comments, thoughts would be greatly appreciated. :)
    Thanks. :)
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Horray. Digital cables are component cables. 75 Ohm. Smack on. 3 QEDs will be great (they also do component QNECT (or similar name) now which look suspiciously like digital cables!;) )
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Any good quality 75 Ohm video cable will be fine for component video, just make sure the connectors are also 75 Ohm rated too.
    You don't say which Unicol bracket you plan to use. The most popular choice for LCD projectors is probably the Gyrolok bracket. This can get the projector as close as 4" from the ceiling, though you'll need skinny hands to get in the gap and fasten the screws ;)
    Regards
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    As above: Sony bracket is crap.Use Unicol and buy direct from them. They are in Oxford, directory enquiries should have number.
    Gordon
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    01865 767676
    Unicol engineering
    Green Road
    Oxford
    OX3 8EU
    Unicol.co.uk
  6. 10ht
    10ht
    Jan 9, 2002
    118
    Swindon
    +4
    I use the Unicol support.The only problem I found was that if you want to swing a 10ht right back as close to the ceiling then the support keeps moving downward. The only way to get over this is to place one of those small plastic white shelf support blocks that can be bought at a DIY shop, at the pivot end to prevent it moving.
    Happy viewing
