Digital Coax to Digital mini-jack cable NEEDED!
Discussion in 'Cables & Switches' started by Jaxkesa, May 29, 2002.
  1. Jaxkesa
    Jaxkesa
    May 29, 2002
    412
    2
    46
    Earth
    +205
    I just got some 2.1 digital speakers for my PC that have a coaxial digital input on them, and according to the manual I need to get a cable that has a digital coaxial connector at one end and a digital mini-jack at the other end, in order to connect my sound card digitally.
    I have it connected analogue style at the moment, but I would like to use the digital output on the card.
    Problem is, I cant find anywhere that sells this cable...i have looked on alot of online stores but nothing, apart from a converter box for £20. I was hoping to find a cable for cheaper than this maybe.
    If anyone's got any ideas then please let me know, thx. Jax.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. Jaxkesa
    Jaxkesa
    May 29, 2002
    412
    2
    46
    Earth
    +205
    Thx for the link. They do alot of useful cables by the looks of it, but no coax digital converters :(
    Thx anyway dude. Jax.
  4. jlo1986
    jlo1986
