Digital Coax Or Optical
Discussion in 'Cables & Switches' started by bigjonnyauk, Jul 23, 2004.
  1. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    762
    midlands
    +17
    HI ALL
    not really a prob but
    i have the following
    ps2
    dvd player
    both of these have optical my amp only has one optical input but 2 coax inputs
    the little lad wants his ps2 going through all the speakers as its great he says lol hes only 7
    so i was thinking of getting a decent digital coax for my dvd player
    is tthis on par with optical , the same or even bit better as there isnt so much processing going on i beleive
    thanks
    was looking at getting this if youre interested
    http://www.tvcables.co.uk/cgi-bin/tvcables/XHD408.html
  2. Ian J
    Ian J
    Aug 6, 2001
    25,629
    +4,906
    To all extents and purposes there won't be any noticeable between co-axial or optical leads although the former is supposedly marginally better
  3. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    762
    midlands
    +17
    so digital coax is supposedley better then mmmm thanx
  4. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Thanks IanJ. I was wondering that to,as have just ordered a pioneer 575 which has both options.
