Digital Coax or 6 MultiCH-Leads or Optical
Discussion in 'AV Receivers & Amplifiers' started by DangerMouse!, Dec 17, 2004.
  1. DangerMouse!
    DangerMouse!
    Jun 16, 2004
    109
    +3
    I have recently purchased a Denon 2910 and was wondering how best to connect it to my Yam 2400.
    Would I be better off using
    1 Digital Coax
    or
    6 Multi Channel Leads
    or
    1 Optical lead
    thks
    p.s. I don't have any DVD-A's at the moment so am just using it for standard DVD's
  2. ADC
    ADC
    Jan 5, 2004
    1,846
    48
    Coventry
    +56
    It depends on the distance between the amp and dvd. For 2 metres or shorter the co-ax is supposed to be better. for longer runs the optical connect is supposed to be better. cant say as i can tell much difference myself. for dvd audio you will have to use 6 analogue leads.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Use digital coax or optical for best quality...
    ... plus less mess!
  4. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    Sorry to butt in, but at the risk of Nick_Uk appearing, if it is a digital out why is there a difference between coax and optical performance? This is baring on mind the recent posts about coat hangers etc in the cable forum - digital is either on or off. I've tried both on my player amp combo and being a numptie can't really tell the difference - perhaps I should have used the coat hanger?
  5. DangerMouse!
    DangerMouse!
    Jun 16, 2004
    109
    +3
    Thanks Guys
    p.s. Coat hanager? I'll have to check out that thread
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    If you have a friendly dealer, borrow one of each and see which works best
  7. russ123
    russ123
    Jul 31, 2004
    832
    46
    South Of The River
    +110
    I have the same amp and dvd as you. For DVD I use Co-Ax. I got a £50 RRP 1m Ixos one from Ebay (fillyourboots) for £29. Am very pleased with it and the sound quality is noticeably better than the £20 Cambridge Audio one I used temporarily.
  8. Lostinapc
    Lostinapc
    since the signal is digital it is either there or it is not there... there is no middle ground. i juse use a cheap video phono lead (a yellow one) as it is 75 ohms, the red and whites are 25 ohms i think. i really doubt there is *actually* a difference unless you experience your audio sporadically cutting out. i've not actually researched this, but it is the whole point of digital, it is lossless.
  9. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I would think the DACs on the player are better, at least more up to date, than the receiver´s, as the player does bass management, you should get better sound with 6 analog ICs...
    Otherwise use coaxial...
  10. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Lostinapc,
    I think you need to research that :)
    Cheers, Carl.
  11. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    I think we have convincingly proven that any cable will do for the
    digital co-ax. That's of course for cables of less that 30 meters,
    where as you already know, line impedence and reflections are
    not significant.
  12. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Some of you guys need to get out and try some coax cables, you might be in for a surprise... :rolleyes:
    Start with the reasonably priced Apogee WideEye... :lesson:
  13. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    I have read many good things about the Wyde Eye cable but the last time I looked, we cannot buy it here in the UK :(
  14. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Buy it on the net, I garanty you wont be disapointed, US$50... :smashin:
  15. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    For $50 it'd be rude not to :D
  16. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Exactly, no risk at all, and it sounds more "analog" than any other coax I tried, including a Siltech I own and wich now connects the cableTV box to the processor... :rolleyes:
    All my friends that tried it kept it in replacement of whatever they had...
  17. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Do you know any good sites that deliver to the uk? :D
  18. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
  19. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I also use Apogee WideEye balanced XLR connecting the processor to the powers, very good too... :smashin:
  20. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Cheers for that lowrider, will check it out :thumbsup:
