Digital camera please help???
Discussion in 'Photography Forums' started by red2004devil, Jul 13, 2004.
  1. red2004devil
    red2004devil
    Jul 13, 2004
    217
    Hi. I have got £120 to spend on a digital camera can anyone reconmended one and where to buy from????
    Ive seen a couple olympus c-160 £99.99
    A KODAK CX7300 £99.99
    A OLYMPUS D395 £99.99
    Please help!!!!!!!!!!!!! :confused:
  2. apreading
    apreading
    Jun 28, 2004
    283
    +15
    To be honest I would personally ignore those and go for the Nikon Coolpix 2200 - should eb able to get it online for £90ish if you search on dealtime etc.
    One really useful item for anyone on a limited budget is that it takes AA batteries so a spare ser costs less than a fiver - and believe me you NEED a spare set on a digicam, plus if you ever get stuck out & about you can buy cheap disposables to see you through... Also takes SD cards which are relatively cheap (£30ish for 256Mb from ebuyer or the like) - I think the olympus usually take expensive XD cards - DO NOT expect to go far on the free tiny cards which come with the cameras they are useless from day one...
