Digital camera (D70) & Moire patterning
Discussion in 'Photography Forums' started by johnmoyle, Jul 16, 2004.
  1. johnmoyle
    johnmoyle
    I have just purchased a Nikon D70 - FANTASTIC!
    However if I try to photograph photos in books journals etc I get bad moire patterning which does not happen with old fashioned photography.
    Any way around this?
  2. apreading
    apreading
    Jun 28, 2004
    283
    +15
    In a word - No! (sorry)
    Some cameras have less of a problem due to the use of a stronger anti-aliasing filter (look up NyQuist if you want the reasons) in front of the sensor, however the tradeoff is sharpness. Basically this softens the image before the bayer interpolation on the sensor to bring the frequency down below Nyquist and avoid Moire. The D70 went for a weaker AA filter to boost sharpness and supposedly does some anti-aliasing in software, but it is hotly debated how effective software can be after the image capture and generally the conclusion is 'not very'. Be thankful - the Kodak cameras dont have an AA filter at all!
  3. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    Buy a flat bed scanner, which will have a scan setting to stop this
    You'll also get a much better copy of the image
  4. Peakoverload
    Peakoverload
    Dec 1, 2003
    917
    43
    +191
    If what apreading is correct wouldnt shooting in RAW bypass this and so get rid of the moir?
  5. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    I thought this was an issue with the sensor chip, and not the file format?
  6. apreading
    apreading
    Jun 28, 2004
    283
    +15
    woody is right - the moire is still captured by the sensor. using RAW does allow for more powerful software techniques to do their best to reduce it as it can spend longer and have more processing power to do the job - but this only works to a limited degree, and only if you have very good software. Kodak and Sigma have put alot of effort into this as they dont use AA filters at all to boost sharpness (plus at the Kodak resolution Nyquist is alot higher and moire is reduced anyway) but Moire is still a problem so they cant fix it properly through software alone.
  7. Peakoverload
    Peakoverload
    Dec 1, 2003
    917
    43
    +191
    Ahh I understand now.
