Digital Camcorders, Tapes & X-Ray Scanners
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Kevo, Nov 27, 2001.
  1. Kevo
    Kevo
    Aug 23, 2001
    5,412
    Manchester
    +151
    Just a quickie.
    Is it OK to pass a digital camcorder & tapes (mini DV) through an airport X-Ray Scanner.
    TIA
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Yep. Took DVcam on hols this year no problems.
    Regards
  3. colinrbarrett
    colinrbarrett
    I've taken all manner of videotape masters through airport security many times. The new (eg: less than 10 years old) machines are no trouble at all, but if you have doubts then hand the tapes to a security operator and ask them to bypass the machine. Sometimes they will, though I have been refused this before. In the light of the current scares, you might be refused too.
    However, in all the years I've been doing this I've never noticed any harmful effect on recordings - digital or analogue.
    Colin Barrett
    Freelance Contributor, "Camcorder User" and "What Camcorder" magazines.
    Website: http://www.simplydv.co.uk.
