Digital Camcorder up to 1000.
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by sirlukas, Sep 22, 2005.
  1. sirlukas
    sirlukas
    Sep 3, 2005
    908
    Woodley
    +91
    Hi, I have quite a problem, a friend of mine is planning to buy camera for up to 800 quid max. 1000 (but better not).
    What would You suggest, DVD Video Camera, HDD Video Camera, or any others? What brands to look for, and what to avoid?
    Links more than welcome.
    Thank You,
    Regards, sir
  2. Roy Mallard
    Roy Mallard
    MiniDV, Mini DV, Mini DV
    Panasonics are good (GS-250)
    Could use a bit more information about the end use.
    Is widescreen important?, Is manual control important?, is there a god?
  3. sirlukas
    sirlukas
    Sep 3, 2005
    908
    Woodley
    +91
    Really MiniDV, not DVD, HDD or Flash Cards? What is the advantage of miniDV?
    I don't think that manual is important, probably for home use, widescreen is not important i suppose.
    EDIT: Look at my posts number ;) My best number.
  4. Roy Mallard
    Roy Mallard
    miniDV is the least compressed cheapest media, universally used, universally available, stable, good quality, compact.... AVI is far better than MPEG2 & 4.
  5. sirlukas
    sirlukas
    Sep 3, 2005
    908
    Woodley
    +91
    So, what Camera would You buy (consider)? Any links?
  6. senu
    senu
    Aug 26, 2005
    19,342
    163
    Hillingdon /Hayes, Middx
    +2,865
    DVD is neither cheap nor flexble for later editing, HDD (JVC Everio) are ( on the face of it) an elegant simple solution but editing out of the camera is not easily possible. Besides how do you archive your footage? .flash cards would require a degree of compression that would render your final quality highly degraded: also not they do not work out cheap ( as they do with still digital photography which is less demanding of space) or easily editable. For cost, availabilty .the least compression and ease of editing you cannot at the present time beat MiniDV
    check this link for hardware.. looks good to me
    http://www.purelygadgets.co.uk/
    Check out the Panasonic GS400 for £748 inc vat . I am saving up! :clap:
  7. Paul_Maycock
    Paul_Maycock
    Yes, Mini DV gets my vote aswell and as a biased Panasonic user I would have to agree with the other contributers.
  8. sirlukas
    sirlukas
    Sep 3, 2005
    908
    Woodley
    +91
    Yes, I considered 3 brands: Panasonic (cause of lens), Sony (cause of lens) and Canon (also lens and overall). Any ideas which one should I erase from the list?
  9. senu
    senu
    Aug 26, 2005
    19,342
    163
    +2,865
    none... Just make sure you hold in your hand before you part with cash. One of the disadvatages of internet shopping. The cameras may be broadly similar in results but feel different regarding ease of use and comfort to sway it one way or another for you. Its a bit like test driving a car and not just relying on pics or looks in the show room .
    good luck
