Digital Cable Woes-PLEASE HELP
Discussion in 'Cables & Switches' started by reno55, Jun 16, 2002.
  1. reno55
    reno55
    Wondering if anyone can help me here. I have an Aiwa receiver and when I use the coaxial digital out on my Adelphia box there is a delay in sound from hearing the voices to their lips syncing with whats on the screen. ( The sound seems to be arriving first). Could it be since I am going through a Tivo?
    My second question is if I use the analog outs on the box the digital channels are MUCH MUCH lower in volume then the rest. Is there a way to boost this?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I don't know what an Adelphia box is but perhaps you are trying to listen to digital sound with an analogue picture as that will cause a sync problem.
  3. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Is Adelphia not an American cable company? If I'm thinking of the right people, have you tried calling them to see if they know what's wrong?
    Try bypassing the TiVo and see what difference that makes... at least that would answer one of your questions.
    If you are using TiVo, wouldn't you connect that to the amp for sound, and not the cable box anyway, unless there is a reason such as broadcast digital sound formats over cable?
  4. AMc
    AMc
    Nov 20, 2000
    6,832
    Near Norwich
    +3,410
    Yes, it is the Tivo. The Tivo buffers everything coming in and then sends it out - to allow rewind, pause and replay.
    To bypass the TV use the AUX button on the Tivo remote to give you a direct pass through.
