Digital Cable Question
Discussion in 'Cables & Switches' started by Howard0000, Feb 12, 2003.
  1. Howard0000
    Howard0000
    Jan 11, 2003
    1,066
    48
    Surrey
    +88
    I have bought a small phono splitter cable for the Coax Digital out on my DVD player, so it can go to the amp in the same room, and the surround sound system downstairs.
    Trying it today however revealed that the amp upstairs does not receive a signal when the one downstairs is connected to the little splitter.
    I am using normal 50 Ohm phono cable...I've heard that if I use 75 Ohm, this makes a difference quality-wise, but this shouldn't be the problem when splitting the signal should it?
    Is it something to do with splitting the impedance through two signals or something that's causing it not to work?
    Help is appreciated.
  2. shodan
    shodan
    Dec 11, 2001
    11,615
    shoeburyness
    +6,587
    Fraid I've got no idea why it may be happening but have you tried putting the splitter in the back of the input on the nearest amp then plugging the lead from the DVD (you made need to get a conveter to change the lead plug from male to female...) but THEN going to the unit downstairs from the amp upstairs?
    Does that make sense or have my "chillout after a poo day" beers made me talk even more rubbish than usual...?
  3. Howard0000
    Howard0000
    Jan 11, 2003
    1,066
    48
    Surrey
    +88
    That's a good idea...so split at the input instead of hte output...I'll give that a try :cool:
  4. Howard0000
    Howard0000
    Jan 11, 2003
    1,066
    48
    Surrey
    +88
    And unfortunately the same happened when I tried that :confused:
    I will probably have to make some sort of mini switch box with phono sockets, a switch, etc to change between the two outputs instead of having both connected. ....That shouldn't cause any harm should it?
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Besides the impedance the loss in a long cable run will be higher and thus cause the signal to degrade.
    If you want cheap 75 Ohm cable use SAT cable from the handy mart though I also would recommend a switch box or booster even (depending on the total length).
    A switch box will of course not cause any harm, just a minor inconvenience.
  6. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Unfortunately you can't split Coaxial Digital outputs, I don't know why, but the recievers can't lock onto the half strength signal. I tried it with several different components when I used to work in an AV store, and it would never work.
