Digital Cable Options
Discussion in 'Satellite TV, Sky TV & FreeSat' started by bwind, Dec 26, 2003.
  1. bwind
    bwind
    I have a home theater with a projector that will accept digital cable with HDTV. We have used the theater primarily to view DVDs and watch TV on a Sony rear projection unit in another room. Next week I am having digital cable installed. The installer is goning to bring one digital cable box with HDTV capabilities for my theater unit and another digital cable box for my other television. My question is... Do I really need two digital cable boxes, or is there a way to utilize one box for both units? If so, how do I change channels with viewing units in seperate rooms? Thank you.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    Sounds like you are from the US, there is no HD via cable in the UK or dsat for that matter, well not yet anyway. You should look at the AVS Forums which is better suited to your needs:)
