Digital blocking/pixel breakup on Pioneer 350
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mr Bigglesworth, Apr 30, 2003.
  1. Mr Bigglesworth
    Mr Bigglesworth
    Although I am generally very happy with my Pioneer DV350, I have on several occasion got a sort of pixel break up/digital blockiness appearing over a frame or two. Normally if I rewind the disc and play it again it won't happen.
    What is this likely to be down to, perhaps a dodgy laser or something - is it worth talking to Pioneer to try and get it repaired/replaced?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i have a 444 pioneer player and have never seen pixelation or break up. Try a few disks if one does this consistently it might the disk, Dirt grease ie finger prints can cause this. If it really bugs you try an d return it for a new one.
  3. Mr Bigglesworth
    Mr Bigglesworth
    Haven't had it happen in a while now, and I've been watching a fair amount of DVD recently, I think I'll put it down to dust or a stray fingerprint as you suggest.
  4. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
    I had a 350 and it did exactly the same thing as yours.
    Blocking, like when digital tv loses the signal.
    Only a frame or two. Not on every disc or even the same disc when played again and never in the same place, but regular enough for me to notice.
    I blamed it on the multiregion conversion but it might be a glitch in the machine.
    Anyone else?
