Digital audio connections
Discussion in 'Plasma TVs Forum' started by Kopacabana, Mar 17, 2006.
  1. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    This is probably the wrong forum for this question but here goes...
    I have a Sony DAV-DZ700FW wireless surround speaker system. The unit has a coaxial digital in and an optical digital in. I want to connect both the the digital audio out from my Sony Freeview box and the digital optical out from my PS2 to the surround unit.
    How should I connect them? Which 'out' should go to which 'in'? Also, bearing in mind its only an audio signal, would it be wrong to buy the TOSlink optical splitter?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Does the Sony have COax digital output? If not you will need a splitter you have to use optical for the PS2
  3. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    The Sony doesn't need an output, it is the amp.
    So, optical from PS2 and coaxial digital from Freeview box. Yes?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    I meant does yor SONY "FREEVIEW" box have coax digital output? If so you are fune if not you arent
  5. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    Sorry. Yes it does.
    :clap:
