digital audio coaxial leads
Discussion in 'Cables & Switches' started by rusty mechanic, May 4, 2007.
  1. rusty mechanic
    rusty mechanic
    Apr 20, 2006
    838
    nottingham
    +68
    hi guys
    would i be correct in saying that digital coaxial leads are similar to hdmi leads in the way that they don't suffer too much from outside interference. the reason being is that i'm going to make one myself using good quality phono plugs from maplins but i've been told that i could use satelite/ cable coax that i've got loads of. would this work well or am i better getting the right sort of cable while i'm in maplins.
    thanks russ
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    Why make one, it is a lot cheaper to buy one ready made, you just need to know where to shop. What length are you looking for.
