Digital 8mm to DVD help
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by jgxp, Apr 9, 2005.
  1. jgxp
    jgxp
    I am looking for a software/hardware kit to transfer my 8mm camcorder tapes to DVD. My camcorder has RCA jacks so I was looking at the Dazzle 150 and a few pinnacle pkgs. Does anyone have any experience with either of these or maybe another that you would highly recommend??
    Thanks for your time,
    John
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    You say in the title of this thread that you want to transfer 'Digital 8mm'. So are you useing a Digital8 camcorder or is it an analogue cam? If it is a D8 cam then you can do the capture cheaply ands easily via firewire. If it is analogue then any of the products you have suggested will be ok.
    Mark.
