digital 8 camcorder help
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by snake II, Jul 27, 2004.
  1. snake II
    snake II
    May 19, 2002
    349
    luton
    +5
    could you all help me in deciding which digital 8 sony camcorder I should :cool: buy? and the cheapest place :lease: :D :laugh:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    If only choosing a new camcorder was that easy :nono:
    So to make life a little easie for us here are a few relevant questions:
    Why Digital8? D8 cams are a lot bigger than DV cams.
    What will you use the cam for? Holidays/kids/stage filming etc
    What is your budget?
    Will you be editing on a PC/Mac? You may well require DV-in if you are.
    Will you need it to play old Video8 or Hi8 tapes?
    Do you just want point & shoot or will you want manual overide controls?
    Mark.
  3. snake II
    snake II
    May 19, 2002
    349
    luton
    +5
    well , the thing is I need it to record holidays trips and on some ocassions lectures . But the most important reason of all is to play d8 tapes, because a relative of mine has one so instead of taking my potential camera on holiday to kashmir where he lives , I could use his to make it that bit easier.
    get the picture?
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    Ok, that makes sense!
    The thing that you must check before useing the relatives cams is - is their cam PAL, NTSC or something else? If its not PAL then you wont be able to play the recordings anyway as only PAL recordings will play in a UK PAL camcorder.
    Also you didn't give a budget.
    Mark.
  5. snake II
    snake II
    May 19, 2002
    349
    luton
    +5
    yeah his camera is a pal version, upto 300 squid, dont want the best of the best only need it for certain days, cheers
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    OK, so I have done a quick search on Pricerunner and Here is what I came up with.
    Mark.
  7. snake II
    snake II
    May 19, 2002
    349
    luton
    +5
    o cheers mate for the info,
