digisender
Discussion in 'Plasma TVs' started by briandzo, Dec 27, 2002.
  1. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    has anyone used a digisender ?
    what is the quality like.
    is it as good as your RGB connections.
    i want to setup home cinema in the bedroom.
    and want to transmit my sky digibox image to a
    plasma TV.
    because as far as im aware plasma tellys dont use
    RF i/ps.
    anyway if this box transmits the RGB sigal and stereo audio
    then this sounds v good.
    but if there anything like wireless home phones then it will be next to useless.
    thanks
    brian.........
  2. KBDVD
    KBDVD
    Aug 25, 2002
    714
    Hertfordshire
    +6
    Hi briandzo,
    I've no experience of the digisender (If this is a specific model and not a generic term) but I do use a wireless RF transmitter to send A/V signals from my video in my front room to my TV in the bedroom. The quality is ok but it does suffer from interference now and again and I certainly woudn't consider it for use within my main setup....NO WAY!
    Best Regards,
    KBDVD.
  3. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Yes.
    Okay on a normal TV.
    No, it uses composite video.
    I use mine to feed the sky stuff to my projector, quality is not too hot when blown up to 7ft, might be okay on a plasma. If you buy it on-line from argos you can return it if you aren't happy with the picture.
    www.argos.co.uk/webapp/commerce/com...nbr=6970&type=big&thisMode=ols&cgrfnbr=379474
