Digisender X400/Gold
Discussion in 'General TV Discussions Forum' started by Homer_J, Sep 5, 2005.
  1. Homer_J
    Homer_J
    Hello All,
    First post on this forum and I hope this is in the right place.
    I have recently purchased the Digisender X4/Gold and have it setup to distribute the signal from my Sky+ box from a first floor bedroom to a summer house in the garden.
    The unit is advertised with a 100 metre range and the distance between the 2 units is probably in the region of 30 to 40 metres with 2 walls.
    Now, I can receive the signal/sound and control the Sky+ box remotely but the problem I have is picture degradation.
    I have switched off my WiFi but this has made little difference.
    Is there a standard 'Guide' to getting the best out of a Digisender or does anyone have any thoughts on solutions etc.
    Kind regards,
    Homer J
  2. JayCee
    JayCee
    Jan 20, 2004
    22,398
    Lanarkshire
    +2,345
    The distance may be the problem as these figures claimed are often wildly exagerated and usually means in free space with no obstructions between.
    As an experiment try moving the remote TV closer and see if it improves.
