Digisaurus
Discussion in 'Plasma TVs' started by the_sanguine, Aug 3, 2005.
  1. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    never heard of them but you will probably want additional or different board to teh svid/cmposite one included.
  3. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    I have sky+, a DVD player and a Video to connect. Will I need a scart board or can I connect them all to my Pioneer amp and then just have a single connection?
  4. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    you still gotta connect the amp to something......if you went the js converter route you could run sky and dvd to the amp and then the amp via js box to the vga on the panel.....you wont get the video through that route though as its not RGB....you could just hook that up to composite board as its going to look bad anyway.....you'd be better of getting a dvdr really.
  5. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    What is this JS box?
    The amp has S-video or the yellow phono plug (is it component out?). Can't I use one of them?
    Sorry If I sound dumb....It's because I'm dumb
  6. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
  7. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    I ordered yesterday at 1.40pm and it was here at 10am this morning. Nice box!!
    What happened with the forum special offer that was a busy thread over the last couple of days? I saw some of you were having delivery problems.
  8. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    OK guys. I managed to cable it all up over the weekend. I'm finding that I'm suffering lip sync problems now. Although it only seems to happen some of the time. What causes it and what's the solution? It's almost as though the plasma has a built in delay?
