Digihome PVR80\160 - s video
tony_yates
Hi All,
I've looked at the various threads regarding the Digihome pvr and have seen the post regarding the Evesham pvr160. The Evesham PVR160 manual suggests there is s-video on the VCR scart socket and some peeps seem to think the boxes (Digihome PVR160 and Evesham) are the same.
So can someone with a Digihome PVR80\160 confirm whether it has s-video on one of the scart sockets? I'm most interested in the Digihome PVR80.
Cheers,
Tony
simbatv1
Hello,
I've had the PVR 80 since Saturday. You can select RGB-CVBS-Svideo on the scart socket. I have not used Svideo so cannot comment on how good it is.
First impressions is thst this box is very good for the money. Hopefully I won't have to eat those words!!;)
tony_yates
cheers for the reply.
As you're happy with it I assume the picture quality is good? I've read elsewhere that it is.
Regards,
tony
sparky_paul
I managed to get hold of a few graded PVR80s, so I can help out with a few comments if you don't mind me butting in...;)
Firstly, RGB picture quality is excellent - one of the best freeview pictures I've seen. Also, the 7 day EPG is also excellent, I prefer the layout (similar format to Sky Guide) to any of the other budget boxes, including my own Fusion. :smashin:
The only downsides to these boxes are no editing facilities, and no twin record - although this can be added with a DIY firmware upgrade. The twin-record firmware has a side-effect that it does slow down the EPG however... Another minor issue is that the timeshift buffer is only activated by pressing pause, it doesn't run continuously - unless you pause for a few seconds then restart.
Apart from these snags, they are an excellent basic freeview recorder. I've seen negative comments about the looks, but personally I think they look fine.
HTH:thumbsup:
tony_yates
Cheers sparky for the comments, gives me confidence in buying one. Sounds just right for us i.e. a good picture, but as it's basic (like our TV watching habits) the price is kept low.
Tony
Podcast: Sony XH95 TV, Klipsch The Fives Speakers & Bias Light Reviews + Best of the Month
