Digifusion FVRT200 - Sound wrong way around?
Discussion in 'Digital TV & Video Players & Recorders' started by Shady Deal, Sep 13, 2005.
Tags:
  1. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Have one of the above PVR's for about a month and overall it is great!! Does have a noisy fan but I can live with that.
    I have noticed however that the sound seems to be coming out the wrong speakers, i.e Left is Right and vica versa.
    It is only connected to the TV via RGB scart and the TV out is connected to my amp.
    I read on the internet that previous models had the sound backwards using phono sockets but not scart.
    Anyone else notice this, took me a while.......
    Mark
  2. awhb
    awhb
    Hi Mark, no, can't say that I have. Have you tried contacting DigiFusion's support and asking them about it?
    -awhb
  3. pr1uk
    pr1uk
    -change the wires around ! sorry never heard of this before-
    but
    Why is the TV connected to the amp, if you have a amp connect all your equipment straight to the amp. I dont see why people let the TV play with the sound first then go to the amp. Plug your freeview, DVD etc straight into the amp after all thats what your be watching get away from this idea of using the TV for sound most are not very good at it and the direct source is so much better.
  4. etaf
    etaf
    Dec 1, 2004
    1,013
    +63
    how do you know from the broadcast?
    I have my amp connected to the fvrt200 phono outputs - but have not played close attention to the broadcast to see what should be coming out of left channel?
  5. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Thanks for the replies, I have thought that occasionally that the sound was reversed, for example a door shuting on the right of the screen has caused the sound to be coming from the left hand speaker etc....
    I'm really not too worried and will speak to fusion in the next week, my main concern is that if I was to burn a recording to DVD that would have the sound reversed also as I would be using scart.
    I am watching/listening for it now, so I guess if it really is backwards I will have to take the scart lead apart and change the speaker wires over.
    Regards
    Mark
  6. etaf
    etaf
    Dec 1, 2004
    1,013
    +63
    I'm a bit worried about occasionally
    so a door on left sounds on right
    so it could be broadcast, FVRT200 internals, Scart out on FVRT, Scart lead, Scartin on TV, internal TV, TVout, TVout cable, Amplifier, amplifier inputs, speaker connections.
    you may want to carry out a process of elimination to try an isolate the issue.
    i would start at the TV out and make sure the cable - amp - speakers is OK first.
    If they are phono leads then just by touching the pin you can get a hum through that channel.
    i have never tried on scart but maybe touching the signal leads will hum through to - keep the volume low
  7. happynow
    happynow
    Jun 14, 2004
    155
    S.Wales
    +10
    Hi, I read your post with interest. This happened to me a couple of years ago now. I can receive signals from both Wenvoe and Mendips. HTV Wenvoe were sending out the Stereo the wrong way round. I contacted them and they replied, admitting it was wrong due to a hardware problem. It was rectified by the time they had replied. See my post here: http://www.avforums.com/forums/showthread.php?t=43591&highlight=happynow
  8. Ramases
    Ramases
    Nov 7, 2005
    36
    I seem to have the same problem. My unit is connected by RCA to my Yamaha amp, and watching "Trial & Retribution" on ITV1 tonight I noticed that when they went into split-screen mode, the sound was coming from the opposite channel to the one it should be from i.e. the one where the action was coming from. I swapped the leads and all was well but this is just the sort of thing to annoy me! I'll be keeping and eye (or rather ear) on this for the next couple of days in case it was just a one-off, but I am wondering if this is an example of the problem reported by "newsposts"?
  9. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Hi Ramases and welcome to the forum.
    Mine is still the same, the only way around it is too switch the leads around to my amp. I rang Fusion and they said they had never heard of it, which is a bit strange as it affected either the 100 or the 150 models.
    I don't mind it too much but I think I may have to have a special scart made up as the unit is connected to a DVD recorder and of course the recorded material will have the sound reversed. Does anyone know what pins/leads that I should change. Even better does anyone know where I could get a scart lead already wired the wrong way round?
    The funny thing it was a while before I noticed it but now of course I am aware of it, it has become very annoying.
  10. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
  11. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    Thanks for that. Yes I was always aware the other models were affected. I shall ring them again I think.
    Regards
  12. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Scart Diagram
  13. Ramases
    Ramases
    Nov 7, 2005
    36
    I emailed them last night. I'll let you know what they say.
  14. Ramases
    Ramases
    Nov 7, 2005
    36
    Well, I got fed up with waiting for an email reply so I called them yesterday. They are aware of the problem and it will be fixed by an over-the-air firmware update "soon".
