DIGIFUSION FVRT145 remote needed
My little daughter decided to spill a full cup of hot tea all over my Digifusion fvrt145 remote control. At the minute it doesnt work but it could still be a bit soggy inside. Is there a replacement one4all or digifusion model? If so, will the one4all feature the full functions, menu, record etc. How much would I pay and where from? I would like one similar to the chameleon. I noticed last week that Aldi was doing a tevion remote similar to the chameleon for a tenner. Anyone triedit?
father alice
The kameleon needs the code downloaded either by phone / internet.
The Kam 6 (series 1) uses code 1645, and features all the buttons except from memory, calendar, skip Fw and Skip Bk , record , Library.
These can be easily programmed in using EFC codes for device 0081. Ask here if you need more info.
The advantage of a replacement remote, is that the IR signal is much stronger, so the remote isn't so directional, plus the layout tends to be a little more logical.
Note that the Kam 4 series 1 is not upgradable.
Note that ANY OFA remote should work, as long as it has vcr code 0081 in it already. It will just take a little more fiddling,using EFCs, than a straight forward upgrade.
Also check ebay, as there are plenty of fvrt100 remotes being sold fairly cheaply. eg http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130019905314&ssPageName=MERCOSI_VI_ROSI_PR4_PCN_BIX&refitem=170001978699&itemcount=4&refwidgetloc=closed_view_item&refwidgettype=osi_widget
One final recommendation I have read is for one of these http://www.freeviewremote.co.uk/index.php?item=27
but personally,I think almost anything would be an improvement on the original remote!
Thanks for those links FA. I missed the ebay cut off. Shame, 2 for the price of 1 and he was local also. My remote has come back to life but for how long-wait and see. I,ve saved the freeviewremotes.co.uk to my faves just incase. Cheers
