digifusion fvrt100 - wobbly image edges...
Discussion in 'Digital TV & Video Players & Recorders' started by mr clutch, Sep 16, 2005.
Tags:
  1. mr clutch
    mr clutch
    I've just got one of these and it seems to be working fine - it's picked up the freeview channels and the image is sharp. However, the image does not fill the whole screen - there is black space at the top and the bottom - and the image seems to wobble at the top and bottom edges.
    It's watchable, but it would be better if the image filled the screen and didn't shimmer at the edges...
    Haven't had freeview before, so apologies if I'm being thick. The TV is a Sony 14" flatscreen CRT.
    Any help much appreciated?
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Seems as if you have the aspect ratio set to widescreen (16:9). - or letterbox. If you are using this on a 14" LCD screen then to fill the whole screen you need to go into setup and set the screen size for 4:3
