Digifusion fvrt 100 unable to record
Discussion in 'Digital TV & Video Players & Recorders' started by scooby do, Sep 13, 2007.
Tags:
  1. scooby do
    scooby do
    Dec 11, 2002
    2,058
    48
    +95
    Guys,
    Is it correct that if you have not had the box on for 14 days and are watching something you cannot use 1 touch record? Also dont even get the EPG for the channel that is actually on, is this not broadcast with the TS. Can do it through the timer option but this is long winded and also the channel rather than display comes up as a block if you go in the next box down it is then displayed correctly
  2. FrankS
    FrankS
    Dec 3, 2005
    422
    28
    +36
    I had a FVRT 200 and they update their 14 day EPG every night at around 3:00am so have to be powered up (i.e. on standby) around then.
    If it's not been switched on then the EPG will not have been populated.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,733
    Somewhere in South Yorkshire
    +6,311
    Indeed. And if, by now, you have left it on or in standby overnight, it will (should?) have a working EPG for the next 2 weeks.
  4. scooby do
    scooby do
    Dec 11, 2002
    2,058
    48
    +95
    Ok as I thought but I was at least hoping that it could get the EPG from the stream for at least the program that was playing alas not for this unit. It is in my bedroom (2nd PVR) and as such not the best device to have whirring away (but this has all been heard before).
  5. Howard64
    Howard64
    Dec 2, 2006
    27
    you can manually set the fvrt100 to record without the epg. I bought one of these 6 months ago and it died. The replacement did not work on arrival. I will not touch digifusion again.
