Digibox to Panasonic DMR E50 problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by BilboBiggin, Jul 24, 2003.
  1. BilboBiggin
    BilboBiggin
    I have just purchased a Panasonic DMR E50 DVD Recorder and having set it up as per book, I am unable to playback any recording from my Sky Digibox in Dolby Pro-Logic Surround Sound.
    Now when I phone Panasonic I am told it will NOT do it.
    Next Time I phone Panasonic I am told it WILL do it.
    I have managed to do the Pro-Logic recording, but I get a RED screen, and when the recording ends I have a VERY LOUD audio loop with a HUGE noise.
    Can anybody tell me
    a) Can I record in Surround from my Digibox and
    b) If so.....How ?
    Thanks for any reply
    A hair pulling out
    Bilbo
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,507
    7
    167
    Birmingham, UK
    +10,222
    Dolby Prologic is matrixed into 2 channels, so if you can record Stereo you can record ProLogic. Are you getting ProLogic and Dolby Digital confused?
  3. BilboBiggin
    BilboBiggin
    Hi Spectre
    Thanks for the reply.
    I have a Dolby Pro Logic Amp that I am using.
    The Panasonic when recording comes up with a box telling you the signal it is getting.
    On normal BBC1 + 2, ITV and Channel 4 it comes up with NICAM, but from the Digibox it comes up with stereo L and R.
    In the set up menus you can set the type of signal the recorder is getting on normal TV but on AV1, AV2, AV3 and AV4 inputs, Digibox is on AV2, then you can't set it up.
    It just comes up with "Auto"
