digibox rs232
Discussion in 'Satellite TV, Sky TV & FreeSat' started by void, May 27, 2002.
  1. void
    void
    I have been trawling the internet trying to find out if you can use the rs232 port on a digibox, connected to a computer, to change channel etc on the digibox from within pvr software. I know that snapstream talks about this with certain specific satellite receivers (not sky digiboxes) using a cable kit. I have read several posts that ask similar questions, but no straight answer so far.
    So, does anyone out there have any information about the rs232 port and whether it could be used to control the digibox from a pc?
    Thanks,
