Digibox manual scart switching CAN SOMEONE HELP!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by syfodyas, Jun 21, 2005.
  1. syfodyas
    syfodyas
    Sep 8, 2004
    282
    +7
    My Sky digibox is connect to my TVs RGB scart socket.
    A DVD player which I used for MP3 playing through my 5.1 system is connected to sky digitals second port and via loopthrough-, when this dvd playerr is switched on, the sky box automatically switiches to the av channel.
    Now what I want is the abilty to manually switch back to the TV picture, so I can have the DVD player on with music playing but see the TV picture at the same time, good for parties etc..
    How can I set this up.
    I use to have a humax pvr 8000t and I did this by pressing the DTV then SOURCE button.
    Please do not suggest I connect the DVD player via s video or composite, I WANT an RGB picture.
  2. Bluevanman
    Bluevanman
    Try going into picture settings and turning scart control off. Can't guarantee it will work, but it's all I can suggest.
  3. syfodyas
    syfodyas
    Sep 8, 2004
    282
    +7
    Scart Control switched off disabled RGB, which makes it pointless.
    There should be a manual switch to toggle between sky boxes AUX and the TV picture. Its ridiclious sky have not made this more clear.
    Anyone have any suggestions at all?
  4. HarryAlffa
    HarryAlffa
    Jan 6, 2005
    61
    With the Sky box switched on, then the DVD player. What about switching the Sky box off, then on again. Perhaps this will set the Sky picture on the TV?
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I think the only way to do this would be to physically break the control wire in the scart cable and fit a switch.
