Quantcast
Digibox cuts prog B4 the end
C
Ca1vados
Quite often when recording a prog, the box cuts out before the end of the last 5 or 10 minutes.
Can I do anything to prevent this or have I bought a duff box?
Regards
Ca1vados
Thornastor
You would get answer if you post it in the Pvr thread.
What model, software and make, TV Transmitter area?
Are you on accurate recording or auto padding?
Garrett
The BBC has been realy bad over the last couple of months not running to time and nearly always over run. But just recently I been adding a bit of time back and front and quite a few times over the last 3 weeks Ive missed beginnings of programs and I know its them that's started early as I have a time log on the recordings.
Garrett
By the way please don't re post the question in suggested forum I'm about to move this for you in which I hope is the right one.
Captainkremmen
OP can you tell us the make and model of your PVR, then we might be able to help.
Also some info on what channel(s) and programs are giving you trouble.
