Digi Sky channel 4 problem
Discussion in 'Sky Digital TV Forum' started by jjsteph1969, Mar 1, 2005.
  1. jjsteph1969
    jjsteph1969
    Nov 16, 2004
    37
    Hi all, we have panasonic sky digi box and the problem is that when we watch Channel 4 we have a intermitted cracking noise from the sound. What could it be?. It's only on Channel 4.
    All advice would be welcome
    JOHN
  2. chrisrich
    chrisrich
    Jun 10, 2004
    Me too. I have no idea whats causing this. It's only been happening to me for about a month or so, ocaisionally I get some artifacts on the screen too. Also ocaisionally get this on ITV2.
    I was ignoring this as I thought it was probably some issue with reception and we are moving soon. Having said that I have 3/4 full signal strength and 3/4 full singnal quality.
  3. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    Panasonics have been known to develop this kind of audio fault when watching the RGB signal output. Strangely enough it happened to me usually whilst watching E4 - seemed to be when they cut to white screens which feature a lot on E4's idents. vaguely remember it's related to the power supply, but don't worry I don't think you're box is about to blow
    My suggestion is to switch to the normal PAL output (I know, it's not such a good signal) and see if this makes any difference. If it sorts the problem I'm afraid you might have to be content with a PAL signal. Of course it might be totally unrelated to what I'm saying but worth a go - let us know.
    Nathan
  4. chrisrich
    chrisrich
    Jun 10, 2004
    Ah that makes sense. I only recently switched over to RGB when I got my LCD TV. Guess I'll be switching back now :)
    Thanks Nathan
  5. jjsteph1969
    jjsteph1969
    Nov 16, 2004
    37
    Hi all, Big thanks for all the advice. I am running the panasonic box with RGB settings. I will go back to the PAL setting. Is there any other way to stop this problem with Channel 4
    JOHN
  6. chrisrich
    chrisrich
    Jun 10, 2004
    Theres a few places on google that can apparently fix the issue. One I found after a quick google was http://www.satcure.co.uk/repairs.htm. Personally I think I'm going to leave it. We only have the freeview channels now; so i'm not overly fussed. When I move I might buy a freeview box then the digibox can go upstairs.
