Digging a hole for myself
Discussion in 'General Chat' started by Thug, Jun 24, 2015.
  1. Thug
    Thug
    Jul 17, 2003
    7,854
    3
    Middlesbrough
    +3,976
    I am building a fence and need to dig about 22 or 23 holes for posts.
    The holes are going to be 2' deep by about roughly 12" square (4"x4"x8' posts). So far so good.
    The area I am digging them is in a wooded area and here lies the problem.
    So far I have dug 3 by hand (well spade actually) and they have taken me several hours to dig EACH ONE!!!
    The reasons being, the amount of thick tree roots I am having to chop through as well as rubble and the fact that the mud/clay is bone dry. I am hitting the spade into the ground and chipping away fractions at a time as well as sending huge shock waves through my hands, not to mention the fatigue.
    Is there any quicker way that you could recommend?
    I thought about an auger, but this would just get caught up in all the roots (or would it cut through them?).
    I have even sharpened my spade so it cuts into the roots better, but its still such slow progress.
    At the moment I am using a normal spade and a trenching spade. I am also using branch cutters to chop through the roots, but still need to clear a lot of earth away before I can get to each one.
    To make matters worse, I have started off digging what I thought would be the easiest ones with out many trees in that area, so haven't even got to the most populated area yet.
  2. SteakAndCake
    SteakAndCake
    Nov 22, 2012
    7,169
    +7,476
    Yes. Take advantage of Globalisation and pay some Polish to do it for you.
    • Like Like x 2
    • Funny Funny x 1
    • List
  3. Rob8980
    Rob8980
    Dec 4, 2005
    946
    St Helens
    +489
    If you can get access with it. Hire a mini digger. Not sure if it will go through the thick roots but it will be lots of fun trying! Think you can hire them for about £80 a day or thereabouts
  4. SteakAndCake
    SteakAndCake
    Nov 22, 2012
    7,169
    +7,476
    Hell, hire two and recreate Robot Wars.
  5. wilbanat
    wilbanat
    Sep 25, 2009
    7,670
    +9,561
    I've said it before, and i'll say it again....
    If a jobs worth doing, then it's worth using massively over powered tools :smashin:
    Hire in a Auger and get a mate to help hold on.
    • Agree Agree x 2
    • Like Like x 1
    • List
  6. Thug
    Thug
    Jul 17, 2003
    7,854
    3
    Middlesbrough
    +3,976
    Cant get access with a digger unfortunately.
  7. Thug
    Thug
    Jul 17, 2003
    7,854
    3
    Middlesbrough
    +3,976
    Wouldn't an auger just get caught up in the roots though?
  8. wilbanat
    wilbanat
    Sep 25, 2009
    7,670
    +9,561
    Nah, something like this would destroy the roots
    [​IMG]
  9. hedrock
    hedrock
    Mar 3, 2006
    204
    +15
    A pickaxe might help to break things up.
  10. Rorifett
    Rorifett
    Mar 23, 2008
    24,872
    Sunny Scotland
    +15,249
    Biggest power tool possible is required here
    • Like Like x 1
    • Agree Agree x 1
    • List
  11. clc.sheff
    clc.sheff
    May 28, 2008
    3,560
    Steel City
    +1,874
    An auger would get you nowhere. You are probably using the best method already. Post and rail fencing is the best so you can put the posts where you think is easiest to dig and cut the rails to suit
  12. John7
    John7
    Aug 6, 2004
    2,848
    +998
    Get yourself down to your nearest Wickes and hire one or two of the migrant workers who congregate there every day waiting for someone to give them work
  13. Thug
    Thug
    Jul 17, 2003
    7,854
    3
    Middlesbrough
    +3,976
    That will be fine for starting the hole off, but when you get 6" deep or more then there is no space for an axe head in the hole, never mind room to swing it.
    I do have a 'one hand' held one I have tried.
    May try a hammer and wood chisel to cut through them, but its still tough going.
    The thing is, I don't know where the roots are until I start to dig. I could end up with loads of 6" holes and still have trouble.
    Not only that, but I want it quite uniform so it looks on too, so putting the post centres 6' apart, the same as the rest of the fence.
  14. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    I believe you can get a landscape bar that is built for these types of jobs.
    Although you're probably just as well with a hammer and chisel.
  15. Sandman
    Sandman
    Nov 28, 2002
    3,776
    Glasgow
    +1,688
    I had the exact same issue when I built my fence last summer. Ended up using a reciprocating saw to go through the routes. A small electric chain saw would also work well. With these tools you should really be able to dig at least 2 or 3 holes an hour.
  16. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    • Like Like x 2
    • Funny Funny x 2
    • List
  17. shahedz
    shahedz
    Apr 26, 2005
    11,104
    +2,038
    You don't happen to live near the Wickes off the A406 do you?
  18. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,484
    Post spike and a bloody big hammer ;) (Or post driver)
  19. happychappy69
    happychappy69
    May 3, 2009
    2,456
    Maidstone
    +197
    • Like Like x 3
    • Agree Agree x 1
    • List
  20. Thug
    Thug
    Jul 17, 2003
    7,854
    3
    Middlesbrough
    +3,976
    The problem with a chainsaw could be if I hit a hidden rock or something. Might be a good idea though. Even an electric one would help.
  21. mikes48
    mikes48
    May 11, 2007
    1,464
    116
    Preston, Lancs
    +1,562
    Auger? Worth a spin? :D
  22. 27neth
    27neth
    Feb 15, 2007
    3,517
    middlesbrough
    +1,346
