dig cam with 8meg and video
Discussion in 'Photography Forums' started by manu1, Mar 9, 2005.
  1. manu1
    manu1
    Need some help: I'm a dermatology doctor and need to take macro shots of small moles, skin blemishes etc.
    I also need to take short video clips of some skin problems (too long to explain).
    So I need a high res (8meg is good) dSLR, with video function, to which a decent macro lens can be fitted.
    Budget could stretch to around 1000 pounds including lens.
    Anyone got any suggestions? As always,many thanks
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,241
    48
    London
    +95
    Whilst I am sure that others will be able to point you in the right direction on your specified requirements (and I am sure you may find a couple of other uses for a camera of this spec :D ) I am surprised that you require such a high spec camera.
    Back when I had a practical job with the insurer I work for I used to interview and have sat in on medical examinations for claimants with personal injury which did often involve photographing the injuries sustained in case of litigations. Whilst I accept that there are differences in priorities we (and the majority of our Drs) found 3-5 mega-pixal cameras in macro mode were more than sufficient.
  3. Crocodile
    Crocodile
    Nov 4, 2002
    15,157
    +4,476
    Check out the Fuji S7000. Should do everything you want straight out of the box for around £300 or £265 as a factory refurb from Fuji. Less than the cost of a proper SLR macro lens.
    I stand to be corrected, but I don't think any DSLRs have a video mode.
    Search this forum for S7000.
  4. seany
    seany
    May 1, 2003
    2,987
    61
    Manchester city
    DSLRS dont have a movie mode. You don't need 8mp for moles ect unless you need to print them at a large size. You could get the canon G6 7mp decent macro function and video mode. For under £400
    But then crocs would do the job
  5. manu1
    manu1
    Many thanks folks, As I expected, you all sound like you have med photography backgrounds (or a strange fascination with skin lesions). I shall look into all the models you mention - pronto.
