Diffrence between DTS
Discussion in 'AV Receivers & Amplifiers' started by RUWANDIGITAL, Jan 25, 2001.
  1. RUWANDIGITAL
    RUWANDIGITAL
    Hello ,
    i wondering if you could hear any diffrence between DTS ES matrixed and DTS 6.1 Discrete??
    Can anyone help me?
  2. Mad Max
    Mad Max
    If you search the site, you will find a topic explainig exactly that.
    Here goes though: Matrix means that the 6th channel is MAtrix encoded into the 2 surround channels of DTS (Like old Pro-logic).
    Discrete means it's a full blown sixth channel.
    That's it basically [​IMG] Very little software available though [​IMG]
    OOps... I should learn to read before answering... [​IMG])
    I'm not sure you can hear a difference... In theory, Discrete should be better, but I don't think there is any software both Matrix and Discrete encoded to make a direct comparison.
    An adult is just a kid with expensive toys.
    Rui
    [This message has been edited by Mad Max (edited 26-01-2001).]
