diffrence between cdr & cdrw and dvdr, dvdrw etc
Discussion in 'Computer Components' started by oxygenuk, Aug 12, 2005.
  1. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    Hi whats the diffrence or whats the standard that is used for making audio cd's? (burning cda's, mp3s to cd etc). theres two types (cdr cdrw) but i dont know which to pick for what i specified above.
    also same goes for dvds. am i right in thinking i should use dvdR's instead of dvdrw's to burn dvd movies (ifos bups vobs way etc) to dvd or what?
    i know the r stands for recordable and w stands for writeable but they both kind of mean the same kinda thing to me virtually :rotfl:
    thanks! :D
  2. Ch0pper
    Ch0pper
    Mar 31, 2005
    246
    +3
    Think of the R as reecordable and RW and RAM as rewritable. Helps keep the difference clearer in your mind when browsing the shelves..
    Recordable - can record on it ONCE
    Rewritable - can keep on recording on it like a VHS tape
  3. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    i see.
    so when something has W that just means u can write media on it more than once basically?
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,319
    Somewhere in South Yorkshire
    +5,674
    Yes. RW means, you can erase it and start over. R means, you can't; once "burnt", it stays "burnt".
  5. john249
    john249
    That reminds me. I need to get some RW discs.
  6. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    also whats the diffrence between dvd+r(w) and dvd-r(w).
    and what should i select? ty
  7. LV426
    LV426
    Jul 14, 2000
    13,319
    +5,674
    The difference between + and - on DVDs is that they are two different and effectively incompatible recording formats, invented by two different companies.
    Incompatible, means that, if your recorder/drive, etc. is designed for only one of these, then it won't work with the other type of blank disc. What it does NOT mean, is incompatible for playback. On the whole, most players and recorders will playback either type of disc, provided it has been finalised.
    Which you should choose depends on what your device will handle for recording. If it will handle both, then there is a school of thought that says - (minus) discs tend to exhibit better compatibilty for playback on other players/recorders.
  8. meansizzler
    meansizzler
    May 11, 2005
    7,723
    104
    London
    +316
    Here is my two cence
    Use - Discs if you intend to make copies of cd's/dvd'/games that are to be played for long period
    Use + Disc if you are backing up your data and only need to access it infrequesntly, i.e to be stored for a long period until you need to access it again..
    DVD RAM discs have the same use as +, for Data storage the only difference being is you can write to it like a hard drive and it lasts longer...
