differnce between panasonic PW7 and PW8?
Discussion in 'Panasonic TVs Forum' started by Davidgilmour, Aug 14, 2005.
  1. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    781
    Amsterdam
    +15
  2. strees
    strees
    The difference is mostly regarding HD compatibility.
    Although the PW8 has a comp connector as standard whereas the PW7 doesn't.
    If your not planning on being an early adopter of High Definition broadcasts
    or pre recorded discs then the PWD7 is a bit of a steal (around £1k).
    If you want to ensure you are compatible with HD later this year/next year then go with a PWD8. The 7 Series Display will be compatible with these technologies though only when playing back NTSC 60Hz R1 Discs (which could cause problems)
    With the PWD8 you can get a board for HD.
  3. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    781
    Amsterdam
    +15
    I already have a PW7 and no money left to upgrade, in holland we dont get HD TV for like 10 years (dutch economy is the worst in europe thanks to the euro) so I dont need a HD TV yet. But what do you say about the 60 Hz ?
    So I will never be able to play PAL HDDVD-s on my Panny ?
  4. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,268
    I have a PW7 with a HTPC connected and it does play back all the hi-def demo's I have thrown at it so far.. it obviously scales them down to its native resolution and to my eyes the 720 stuff looks better than the 1080, maybe because of less scaling.
    I think there are issues with connecting Hi def players to the PW7 than only output at a fixed resolution and refresh rate that the panel will not support - hence no signal detected. If you use a scaler or a HTPC to scale, it should work fine.
    Appreciate some comment on this as I think I have it right, but it is a very confusing area :confused:
  5. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    781
    Amsterdam
    +15
    What is a HTPC ?
  6. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,268
    A Home Theater Personal Computer.... basically its a pc that lives in the lounge, it is connected to my PW7 via DVI and to my amp via spdif (digital audio out).
  7. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    781
    Amsterdam
    +15
    Ah, I see. And the HD trailers from Microsoft :D .
    I have a PW7 with JS RGB/VGA board in slot 1 and Component in 2.
    No room left for DVI, what other way am I gonna connect HD gear in the future?
  8. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,268
    You should have at least one free slot... The 37" has a VGA port plus two slots and 42" has a VGA port plus 3 slots..
    For an experiment you could just take your pc to the plasma and connect it via the VGA port (disconnect the JS Tech thing) and playback some hi-def files off your pc.
  9. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    781
    Amsterdam
    +15
    lol, the JS thing is connected to the VGA, so you are right, still one left for DVI :D
    Where can I download some HDTV stuff on the internet?
    Will try to watch it with the VGA connection.
    thanks
  10. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,268
    Here are some demo's to get you started Microsoft Silverlight
    Also, try a google search on 'usenet'
  11. jcinzano
    jcinzano
    aside from upgrading the features, there's not much difference. not much point to evolve their SD unit since there's not much likelihood that they'll even make a 9 series next year.
