Different versions of K800i?
Discussion in 'Mobile Phones Forum' started by drunkenmaster, Jan 1, 2007.
  1. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,569
    The Shaolin Temple
    +43
    When comparing my Tmobile K800i with an Orange K800i (as one does:rolleyes: ). I noticed that the menu icons were diferrent on each phone. Is this a provider branding proviso or is this more related to firmwre updating??
  2. siany
    siany
    Dec 28, 2006
    431
    Near Ipswich
    +21
    Yeah those networks brand their phones so things like menu icons and shortcuts etc will be different. If that bothers you, you can always get it debranded to get rid of network software and icons :D
  3. hot-fuzz
    hot-fuzz
    Dec 13, 2005
    6,086
    Hampshire/Surrey, UK
    +593
    Yeah, each operator tries their hardest to out do the other operators by making the menu system USELESS.
    I think the more useless the menu system the more points each operator get.
    Orange are way in the lead.
    Just get it debranded by buying a flash cable and downloading the latest SE K800i software. I did and best thing i did.
  4. simon k
    simon k
    Dec 7, 2005
    117
    +4
    Where did you download the software from I am going to order one of these phones this week.
  5. Autopilot
    Autopilot
    Feb 5, 2005
    7,598
    Region 2
    +1,495
    Remember you will need to flash a new version of the firmware. This will invalidate your warranty. If you phone breaks down they may not let you have a replacement. My advice for most people is stick with operators version. Live with that for a year, and then 12 months later (when it's time to upgrade) de-brand the phone with a generic firmware version - which will increase the second hand value on eBay etc.
    Also, all the network operators have their own version of the firmware and it's not just about icons etc, i have found things like GPRS not working after a firmware upgrade - manual settings would not work, but this is not the norm to be fair. Make sure you know what you are doing, or you can brick your phone.
  6. hot-fuzz
    hot-fuzz
    Dec 13, 2005
    6,086
    +593
    Here :
    http://www.wotanserver.com/
    My advice is, do it, it speeds the phone up and makes it a much better phone to live with.
    The chances of breaking it is very rare and the pros FAR outway the cons.
    :thumbsup:
