Different Sound Zones
Discussion in 'AV Receivers & Amplifiers' started by Nobber, Oct 11, 2005.
  1. Nobber
    Nobber
    Nov 29, 2001
    317
    Not sure if this is the right section
    I'm interested in discovering the best way of distributing sound around the house with perhaps 3 zones
    1. What type of amp/reciver should I consider
    2. Cables/wireless whats available these days
    thanks
    Nobber
  2. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,024
    Harrow, NW London
    +599
    choices are
    Denon do a top flight amp that i think has 3 zone capability, 5.1 in one zone, then 2 stereo zones.......cant remember but i think it has 3 video zones as well, but it might just be 2.....that will cost £3,500-4000 depending where u buy it....
    Server system, Cyrus and Yahama i think make the two main consumer ones, they are not cheap either, usually u pay a grand or so for the main unit, then so many hundred for each client, however i think you can have quite a few clients hooked up....i think one or both is wireless for sending mp3 quality or wired for CD quality......check the respective companies websites for more info.....(possibly cost around £3,000 for probably 4 zones total, cant remember off top of me head tho)
    then you have the more business like approach, proper switch boxes with multiple sources, probably the least cheap for a home user, usually to make these cost effective your talking half a dozen zones minimum, more likely a dozen or upwards....
    um, im sure there was another one, but i just got distracted watching Nevermind the Buzzcocks...lol....sorry, hope some of this is helpful...
  3. Nobber
    Nobber
    Nov 29, 2001
    317
    Thanks, I wasn't sure if I was behind the times and whether or not there was some sort of ipod type wireless solution
    Nobber
  4. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,024
    Harrow, NW London
    +599
    i think Apple has something for ipod that u plug in the wall socket that allows you to send wirelessly, cant remember, vaguely thinking its called AirPort or something similar.....
  5. wingnut1
    wingnut1
    Aug 31, 2005
    262
    Try the Sonus wireless system, Seems to be getting good reviews in the press and i have heard it sounds fabulous!
