Different signal strengths
Discussion in 'Satellite TV, Sky TV & FreeSat' started by IanK, Dec 27, 2002.
  1. IanK
    IanK
    Oct 19, 2002
    42
    I've got a Sony KD32DX100 with software version number r1.03 & loader v1.01.
    On BBC1/2 & ITV the signal strength shows about 90-95% however on the other channels The Hits etc. it shows about 20% and the picture is heavily pixelated. I'm guessing that some channels are broadcast at higher powers ? Do I need a new aerial ?
  2. Fernsehman
    Fernsehman
    Have you checked that your existing aerial is suitable for the range of frequencies used in your area? If you haven't or can't then you probably need a new aerial of the correct type.
    Also, if you haven't fitted so-called "digital" cable (i.e. double-shielded copper-on-copper coaxial cable such as H109 or CT100) in one continuous unbroken run from aerial to Digibox, then you can expect problems.
    I read info about this at the SatCure web site.
    Fman
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    The radiated power does differ from multiplex to multiplex. However, you may be in the rare situation where your major channels are the only ones being broadcast from your usual transitter, and the minor ones you are picking up from a different transmitter - in which case the overall signal may be weaker and/or your aerial may be of the wrong type and/or pointing the wrong way.
    Details of the transmitted signals, their power, and the most suitable type and polarisation of the ideal aerial can be obtained here:
    http://www.itc.org.uk/tv_in_your_area/INDEX.asp
  4. IanK
    IanK
    Oct 19, 2002
    42
    Thanks for the reply gents. With your help it appears I'm not pointing at the correct transmitter. The one I am pointing at doesn't have 'The Hits' etc. I'm impressed I'm picking them up from another transmitter as it about 90 degrees out, a different aerial type and different polarisation !!
