Different ffdshow configurations for different file types?
Lobo
I have set up an HTPC using Meedio. I want to use Zoom Player to play all my files, but want to only use ffdshow for standard def sources such as DVDs. For my hi def content I dont want to do any post processing. Is it possible to configure this?
kilobulb
with zoomplayer if you only want it to use ffdshow for dvd use the FFDShow Raw video Processor.
If you want differen profiles for resizing etc for different filetypes,resolutions etc you can set them up under Image settings in the ffdshow configuration. These can be set to load on various factors such as file extension or resolution.
